Revit Architecture
Valued Contributor
RJK42
Message 1 of 4 (137 Views)
Load Family
137 Views, 3 Replies
11-19-2012 07:10 AM
I searched for corrugated metal siding and found an rfa file that is useful for a project that I am currently working on.  I want to creat a wall with this.
I click on the insert tab, "Load Family", go to the appropriate location and opened "Corrugated_Metal_Panels_6304.rfa".
But now when I try to implement that for my walls, I cannot locate it in my project browser.  I would like to duplicate a wall and use that for my finish layer but seem a little stuck on how to do that.
Thanks!!
I attached the file.
Employee
loboarch
Message 2 of 4 (133 Views)
Re: Load Family
11-19-2012 07:20 AM in reply to: RJK42
The family you attached to your post is a face based generic model.  This would need to be manually attached to the wall after it has been placed in your project.  There is not a way to directly use this in your wall family as a finish layer.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Valued Contributor
RJK42
Message 3 of 4 (125 Views)
Re: Load Family
11-19-2012 07:27 AM in reply to: loboarch
Thanks for the quick response.  Does Revit have such properties in architecture or structure?? Or is this something that I will have to create.
This structure is typically a pole barn.
Thanks again!!
Employee
loboarch
Message 4 of 4 (111 Views)
Re: Load Family
11-19-2012 10:40 AM in reply to: RJK42
The wall tool in Revit does not allow creating a layer with a profile like this.  It would need to be added as a face family like this if you needed the profile modeled.  If it only needs to be represented in a plan and elevation you can probably do this with a material and the cut and surface fill pattern assignments.
Jeff Hanson
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
