Load Family
4 REPLIES 4
Symo90
484 Views, 4 Replies
Load Family
I have installed Revit 2013 but I don't have the default project template loaded (I don't know why...).
I decide to make my own project template and for doing it the first step is to load the necessaries families but I don't know how to load all families in one time (for example all the australian libraries).
Is there a way to do it?
4 REPLIES 4
CoreyDaun
in reply to: Symo90
There are add-ins such as the Family Loaded Pro that can do this.
Symo90
in reply to: Symo90
Thank You very much! 🙂
Symo90
in reply to: Symo90
But is a payment software... T.T
CoreyDaun
in reply to: Symo90
I'm sure that there are other programs out there then, but I don't know of any (I don't use them).
An alternate method, if it helps, is to create Shortcuts to all of your Families (Explorer » select all » right-click » 'Create Shortcut') and then move all of the shortcuts into a single folder. Revit can load in these families by selecting the Shortcuts, and you can load in all of the Families (via the Shortcuts) within a single folder pretty easily.
Rail Community
