Linked revit file to DWG
3 REPLIES 3
maximbodearcas
7086 Views, 3 Replies
I'm having issues with  masterplan with multiple linked revit files I need to export to dwg. It exports all links individually for each instance. And the main file doesn't get exported. Does anyone know how o work around this issue?
3 REPLIES 3
If you export orthogonal views from Revit, you get flat drawings in AutoCAD.
If you export from a 3D view in Revit, you get a  3D model in AutoCAD.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
That I already knew, but when I export a flat view lets say the first floor, Revit exports every linked file from the masterplan seperate. That means if I have 10 linked files in the masterplan I get 10 seperate DWG files and no masterplan with all the links in (like an exref).
I read on the internet you can bind the masterplan file and then export to DWG, this works but then I lose the function of the link files and this took me about 3 hours to bind. But I have my DWG file.
But still, is there anybody out there that knows a better way to do this so that I can keep my linked files in the masterplan?
From the General tab of the Export Setup dialog box, uncheck "Export views on sheets and links as external references"
