Linked Revit File Hatch Missing
0 REPLIES 0
Message 1 of 1
archjettbautista
533 Views, 0 Replies
Hi, I'm using Revit Architecture 2013.
My work is to make 3D architectural and Structural model of a building because we need to check the building architecture design in relation to structural.
So basically, we linked the Structural model to Architectural and look for the difference.
First, I make an overlap of the two data( Structural data linked to architectural data)
Second, I make hatch/pattern or change the color lines/weight of the structural so I can easily check the difference between the two.
The problem:
(1)on my screen(2D-section), I can see the hatch I made for Structural data(cross pattern colored red) but when I tried to print, it doesn't show.
Solution:
I use the line work tool (overhead line).
(2)(2D-section) i cannot see the hatch pattern, but I can see it on 3D section.
I tried the same solution I use on my previous problem, but it didn't work.
Please help. thanks alot.
Tags (2)
0 REPLIES 0
