Revit Architecture
Active Contributor
yetirawr
Message 1 of 3 (475 Views)
Linked Cad Drawing (EDIT)
475 Views, 2 Replies
07-11-2011 03:44 PM
question:
I am trying to find out if there is a quick launch for editing a linked cad file in autocad?
for example:  I have a linked cad plan on a sheet in revit and would like to edit some layers, is there anyway to select the cad in revit and have it launch autocad and open that file?
or do you have to manually open the file from it's folder path, save, and reload?
thanks
also i am primarily using 2009, sometimes 2011
Employee
ryan.duell
Message 2 of 3 (464 Views)
Re: Linked Cad Drawing (EDIT)
07-12-2011 06:11 AM in reply to: yetirawr
Unfortunately there is no method to launch a CAD link and edit the CAD file in AutoCAD.
You can select the CAD link in Revit > Delete Layers, should you wish to remove specific layers from all project views.
Thank you,
Ryan Duell
Revit Clinic
@revitclinic
New Member
jojo-yce
Message 3 of 3 (383 Views)
08-22-2011 07:54 AM in reply to: ryan.duell
So it is not possible to link a CAD file to another CAD file? ..
Because I have a map with buildings and I want every building has a link...
Thanks!
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
