Linked Cad Drawing (EDIT)
2 REPLIES 2
yetirawr
1736 Views, 2 Replies
question:
I am trying to find out if there is a quick launch for editing a linked cad file in autocad?
for example:  I have a linked cad plan on a sheet in revit and would like to edit some layers, is there anyway to select the cad in revit and have it launch autocad and open that file?
or do you have to manually open the file from it's folder path, save, and reload?
thanks
also i am primarily using 2009, sometimes 2011
2 REPLIES 2
ryan.duell
in reply to: yetirawr
Unfortunately there is no method to launch a CAD link and edit the CAD file in AutoCAD.
You can select the CAD link in Revit > Delete Layers, should you wish to remove specific layers from all project views.
Thank you,
Ryan Duell
Tags (2)
in reply to: ryan.duell
So it is not possible to link a CAD file to another CAD file? ..
Because I have a map with buildings and I want every building has a link...
Thanks!
