I'm using Linked Files in Design Options.
E.g. a Linked File for the front elevation at ground floor, and for the front elevation at first floor, a LF for the right elevation, and for the left and back elev. also. (see attachment)
When I whant to use Linework in a Perspective View to hide the lines between two Linked Files in different Design Options, I do that like this: A: 1. Select Design Option with Active Design Option (at bottom of screen). 2. Select Linework in Ribbon. 3. Select Line Style <Invisible lines>. 4. Select lines in the view to hide.
B. Now I want to hide some lines in another Design Option in the same view: 1. Select another Design Option. 2. Now I can't select lines in the view to hide, I first have to switch to another Line Style and back to <Invisible lines>, otherwise it wont work. 3. Select lines in the view to hide.
Is this (step B.2.) a known problem?
