Hi Tony,
what type of family is the Text Label imported into Generic Model Line Based Family? It couldn't be an Annotation Symbol..is it a Detail Item or what else?
Constantin Stroescu
Constantin, I first created a annotation family, set it's parameter, then opened a Metric Detail Item line based, imported the saved annotation family, shared the parameters, drew a line, but like mentioned if I rotate the line 45°, the text rotates too.
Example:
I tried both the Metric Detail Item line based, and the Metric Generic Model line based. Both result the same?
Hi Tony,
try the attached .rfa to see if it suits you :
I used Generic Model with a nested Label.
Constantin Stroescu
