Is there any any process to see the lighting fixture in front of Room name text. We have attached a snap for reference.
Thanks in advance!
Not really. Annotation elements will always display on top of model elements and the Filled Region. Even if you have the Room Tag and the model elements or Filled Region on separate Views and then overlay them on a Sheet, the Room Tag will still always be on top even if that Viewport is actually on the bottom.
Thanks for your feedback. So for now we can't do this in Revit. If this is possible in future release then it will be very helpful to all of us who need this type of facility.
I wouldn't count on this functionality being implemented into Revit. To me, this would be a poor drafting technique as Tags become "covered up" and their information hidden, or even partially hidden; possibly leading to misinterpretations. The Tags should be adjusted to accommodate the model elements. Could you elaborate a bit on why this functionality would be beneficial to you? Also, below is a link that is frequently posted by Autodesk Support personnel here where you can submit your request directly with Autodesk.
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
