All of the products in our 2014 Educational Master Suite launch and obtain a license from our NLM server properly, except Autodesk Revit Architecture 2014. It continues to display errors. I have turned on verbose messaging for the errors and have been able to take screenshots of the errors that prompt when attempting to open. None of the FLEXnet feature codes showing in the images are for the suite that our school district has. Our FLEXnet Autodesk feature code is 86112EMS_2014_0F.
Error message from log file (C:\ProgramData\Autodesk\AdLM\REVIT2014ENUAdlm.log) is:
1904 2013/07/25 08:42:47 Reason=Fatal error
1904 2013/07/25 08:42:47 ComputerName=DO-IT-W7TESTBOX
1904 2013/07/25 08:42:47 OS=6.1.7600.
1904 2013/07/25 08:42:47 File=AdlmIntNWFBLicense.cpp,Line=782
1904 2013/07/25 08:42:47 VendorID=3 [FLEXLM-NW]
1904 2013/07/25 08:42:47 VendorError=-18 [License server system does not support this feature.]
1904 2013/07/25 08:42:47 FLEXLM-NW=v11.11.0.3 build 118111 x64_n6
1904 2013/07/25 08:42:52 Reason=Fatal error
1904 2013/07/25 08:42:52 ComputerName=DO-IT-W7TESTBOX
1904 2013/07/25 08:42:52 OS=6.1.7600.
1904 2013/07/25 08:42:52 File=AdlmIntNWFBLicense.cpp,Line=765
1904 2013/07/25 08:42:52 AdlmIntError=20 [License check out failed]
NLM is running and handing out license to for other products in the Master Suite license. There is only one license file. What am I missing?
already a thread on this:
it could be a bug with the Educational Master Suite 2014
i would contact your educational license supplier and have them create a case with autodesk
DarrenP
it is a known issue
here is the workaround: http://upandready.typepad.com/up_and_ready/2013/07/education-master-suite-2014-revit-2014.html
DarrenP
