I started with a file with just 2 levels named Level 1 and Level 2. I then switched to an elevation view, copied Level 1 down, and renamed it to "Footing", but the new layer does not appear in the Floor Plans list in the Project Browser. What’s the correct way to do this?
In the same file, I inserted an AutoCAD file, traced the walls, and added a footing. The footing however does not appear. I know I am doing something wrong, but can’t figure out what. Thank you for your help.
Solved by constantin.stroescu. Go to Solution.
In order to allocate a View to this Level: View > Create > Plan Views >Floor Plan > New Floor Plan - select the New Created Level - OK . Now you will have the View of the Level in Project Browses and the Level Head will be blue.
In order to view it , increase the View Range > Bottom and View Depth values (use negative value) to show elements under the selected Level
