My leader for my room tag is waaayy far away from my tag. The leader/border offset is set to 0, but that doesn't resolve the issue. Does anybody have any ideas how to solve this? (the leader and tag are in blue on the png)
Solved by L.Maas. Go to Solution.
Louis
Please mention Revit version, especially when uploading Revit files.
Hi I had this issue but the issue was not an invisible element making the extents bigger it was the label positioning inside the FE if the label is not positioned in the center of the reference lines than the leader will not connect to the tag correctly when it is used in a project. This issue was with an OOTB Autodesk Revit Family Duct Accessory Tag.
