Leader export problem
1 REPLY 1
BIMAbhi
339 Views, 1 Reply
When we export the leader with text into dwg then the leader breaks into line. Can we resolve it. We want to see the same functionality of the leader as in Revit.
Thanks & Regards
BIMAbhi
1 REPLY 1
CoreyDaun
in reply to: BIMAbhi
I don't believe that there is any way to maintain the leaders' functionality through a DWG export. Even embedded Annotation Symbols in families are not converted to AutoCAD blocks and are instead exported as lines.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
