Landscape floor, paving
4 REPLIES 4
5223 Views, 4 Replies
What is the best way to make a paved surface with 10cm of spaces between each 30cmx30xm paving block?
Also, part of this floor construction needs to be sloped.
4 REPLIES 4
loboarch
You will need to create a custom model fill pattern that can be applied to a floor object.  The floor objects in Revit can be sloped.  You can also use the shape editing tool to give a floor object slope.
If this is an ourdoor space like a pation you may also consider using a sub-region on a toposurface object to define the patio.  This will retain the slope of the toposurface.  One drawback with this method is the fact toposurface object can'tr display surface patterns
Jeff Hanson
Principal Content Experience Designer
Revit Help |
loboarch
in reply to: loboarch
The Hatch-22 add-in may help you to create the custom fill pattern you described in the first post.
Jeff Hanson
Revit Help |
Thanks Loboarch, I wil try it out.
A landscaper will be able to evaluate the slope of your land and make recommendations for improvement. Draining water from your home includes a quality gutter system, sloping of your yard and installing a drainage system underground. A landscaper can help you complete many of these tasks so that you are able to limit the amount of exposure your home has to standing water.
Timber Windows
