Kitchen design - Revit Building or Inventor
13 REPLIES 13
Message 1 of 14
3693 Views, 13 Replies
I feel a parametric solution is best.
I believe both Revit Building and Inventor have excellent graphics rendering
capabilities.
If I wanted to produce 3D images, elevations, sections, etc of internal room
layouts, such as kitchens, bathrooms, etc. Which product would you recommend
and why ?
Regards
Tiss.
13 REPLIES 13
Message 2 of 14
Hmmm Our cabinet designer usses a specialized application that works like
Revit, but is for kitchen design. I forget the same, but I will find out
and do a follow up post.
Best Regards,
Bobby W Parker
www.whitebirchstudios.com
"Tiss" wrote in message
news:5252526@discussion.autodesk.com...
capabilities.
and why ?
Regards
Tiss.
Message 3 of 14
That's probably GIZA wwhich is popular in K&B and ID. It's biggest plus is
that many manufatures supply cabinet information for the program.
As to the original question. Revit would be simpler to use than Inventor for
layout and design. The only advantage you would have with Inventor would be
the ability to likn to CNC equipment for manufacturing.
"Bobby W Parker" wrote in message
news:5252576@discussion.autodesk.com...
Best Regards,
Bobby W Parker
capabilities.
and why ?
Regards
Tiss.
Message 4 of 14
no... if I heard the name I would know it. He was using 20/20, but this is
supposed to be better.. again, I'll look into it.
Best Regards,
Bobby W Parker
"Aaron Rumple" wrote in message
news:5252565@discussion.autodesk.com...
Best Regards,
Bobby W Parker
capabilities.
and why ?
Regards
Tiss.
Message 5 of 14
Looking at GIZA web site, made reference to a product CAD Studio.
That wouldn't be what you were thinking of ?
I wish to produce visuals, layouts, etc. No CNC or fabrication drawing
required.
Thanks for the feedback.
Tiss.
news:5252605@discussion.autodesk.com...
Best Regards,
Bobby W Parker
Best Regards,
Bobby W Parker
capabilities.
and why ?
Regards
Tiss.
Message 6 of 14
I think there is another issue here, in that it involves deliverables.
Meaning if the Architectural firm is doing there work in Revit or ADT or
Autocad, the consultant regardless of what software they create there info
in, should be sending back files that can be opened by the achitect and
attached as part of their project.
Bob
news:5252715@discussion.autodesk.com...
required.
Tiss.
Best Regards,
Bobby W Parker
Best Regards,
Bobby W Parker
capabilities.
and why ?
Regards
Tiss.
Message 7 of 14
20/20 is the company. 20-20 GIZA is the software name.
Best Regards,
Bobby W Parker
Message 8 of 14
You a designer? A cabinet shop? An Interior decorator? An Architect? A fabrication shop?
A little more information as to what you do (or are planning on doing) would let us give better advice.
Jeffrey
Message 9 of 14
I know of a kitchen designer who uses 20/20 as well, and has had no complaints that I know of.
Message 10 of 14
The idea is to provide design service to kitchen / bedroom retail outlet.
So would create models of their range of products and 'drag n drop' a
solution.
Easy huh ? 😉
wrote in message news:5253928@discussion.autodesk.com...
fabrication shop?
Jeffrey
Message 11 of 14
mykitchen
I don't know anything of the top of my head, but you can check this really good sit dedecated to kitchen backsplash ideas and designs
www.mykitchenbacksplash.com
Message 12 of 14
I am not really, but if you I think you can find out by visiting this site about kitchens:
http://www.mykitchenbacksplash.com/
I think it is a very good site check it out..
Message 13 of 14
if you I think you can find out by visiting this site about kitchens: I think it is a very good site check it out..
http://www.justkitchenbacksplash.com
Message 14 of 14
of those options revit is the better by far. the tools are all there. i've no clue why you'd want inventor for it.
there are a boatload of low end cabinetry programs that for the price of a seat of revit it'd be worth pickign up a few and seeing if they'll do what you need.
