It is not possible to attach a keynote to linework. You need to have a
detail component to attach a keynote. In order to edit the TXT file for
keynoting you have to open it in an external editor. the is no way to open
the file inside Revit.
Jeff Hanson
Autodesk - Technical Publications
Building Solutions Division
Manchester, NH
_______________________________________
wrote in message news:5474253@discussion.autodesk.com...
I am doing a 3" = 1' detail of a window head detail. I have figured out how
to use the element keynote for model components and detail components, but
is there a way to assign a keynote to line work, say a piece of flashing? I
don't want to just place text on it because then there will be no continuity
in the naming throughout the set and it seems like more work then necessary
to create a detail component for a piece of flashing.
Also, is there a way to modify the TXT file in Revit or do I have to open
the TXT file directly?
