Right click the Revit shortcut and select Properties from the context menu.
In the "Start in:" field change the path to where ever you want the journal
files to be placed.
hth
jason
"Lawrence Garcia" wrote in message
news:424dd0ef$1_2@newsprd01...
> Does anyone know how to modify where the journal files are created in
> Revit? Because of admin restrictions, Revit does not write the Journal
> files into the directory located in the Program Files location. Is there a
> way to assign where the Journal TXT files are written to? Let me know
> Thanks.
