Hi
I have a wall and floor which have basically the same layers. Is there a way to connect floor and wall layers like they connect at wall corners - ie on the attached picture on the left there is a vertical section of wall-floor connection. What I'd like to achieve is connection similar to the right picture
Many thanks
you have to adjust the floor border position in sketch mode as in my attached screencast....
https://screencast.autodesk.com/main/details/ab6c5c3a-75b6-4451-a404-6512de729c03
Your Name
