I have an exterior wall (CMU with brick veneer and interior metal furring/gypsum) that has a corner and am trying to join with an interior metal framed gypsum wall and a CMU structural pilaster furred out (made from the wall function) but no matter how I try to join or connect them there are issues with the "join". Either the CMU pilaster shows metal framing going through it and you dont see the CMU pilaster portion or ! Does anyone know how to resolve this? These are all wall components (Exterior wall, Interior wall, Pilaster).
I have tried to...
1. "Disallow join" so I can butt the interior wall to the pilaster
2. "Allow join" doesn't work.
2. "Wall Join" function doesnt work.
Any help or direction would be much appreciated!
As well as the Clean-up group (priority) you must also match the material and have the furring in the core boundary. I then use an architectural column as the wrap condition and a structural column for the pilaster. You will find that Revit will still fight you tooth and nail with minor clean-up discrepencies (You should get a laugh at me stuggling with this at the end of the video!) Good Luck you may need it.
