hi
I want Wall Arch Picture below With Side walls Join But it does not connect properly and reasonably
Please help if you can.
Attache Join Wall.rvt and Saved Revit 2014
Try joining the two walls then modifying function of wall layers 1, 2 , 6 & 7...
Hi
Thank you for the reply .But there is a problem.
See the picture below.
Depending on the scale of your drawing on the sheet that may not be seen???... bigger fish to fry
However, this should not There is Solutions must be found for.
Cost estimates are wrong because.
a workaround can be to make a: Component > Model in Place > Family Category and Parameters > Walls >Name > Extrusion - make a Void and Cut the extra wall with it....
Constantin Stroescu
Dear Friend
I know But I want to know Is there a way to have their walls This situation can be corrected Model-In-Place and need not
