Hello, can you tell me when it's ready for the Italian language pack inserted in the version of Revit Building Design Suite Premium 2013? thanks
Hi
I did what you wrote. I also changed Revit.ini file to set proper language but nothing happened. What is funny:
"DefaultTemplate=Stavební šablona=C:\ProgramData\Autodesk\RVT 2013\Templates\France\Construction-DefaultFRAFRA.rte" ... this is a default path for Czech Template... France.
Gooood jooob.
Can somebody tell me if it realy works and what shoud I do to make it happen?
Thank you
Rudolf
you should download proper language pack from subscription center, not from autodesk webpage. And check if it is for suite or architecture/structure/mep only.
Rudolf
Hi!
I've this same problem with polish language pack for Building Designs, I install with your instruction but that still dont work!
Could you provide more details regarding your problem installing the Polish language pack? Is there an error message and when do you see the error message; during the install setup, at the end of the installation process or when attmepting to launch the product? Hopefully with a bit more information, we can get the language pack installed and running on your system.
Tony Michniewicz
Autodesk Revit QA
I would like to install Revit 2013 with Polish language pack. I have Revit version of Building Design Suite Premium 2013. I follow your instructions and it is still not possible to change to Polish. If someone managed install the language pack? Should not the appropriate language version appear here during the installation?
