Issues with the View Property of "Detail" Callouts
3 REPLIES 3
JustBrev
2786 Views, 3 Replies
the problem:
structural column is not visible in detail callout when detail level is set to medium or fine.
the situation:
I am taking a detail view"detail" callout of my building envelope in Revit Architecture 2012. I have applied view template "Architectural Section" with structural column box ticked. Detail level set to Medium, and proper scale chosen.
other facts:
the visibility settings of the structual column family are ticked for visiblity in plan view & when cut in plan/rcp at all detail levels.
the column is visible in the above sinario when detail level is set to coarse.
the question:
what else would effect this sturctural columns visibiliy in the "detail"callout ,only?
3 REPLIES 3
vector2
in reply to: JustBrev
Let's do this through a process of elimination.
Is the callout tag outside of the parent view’s
crop region?
Did you check the "Hide at scales coarser than"?
Just for starters.
JustBrev
in reply to: vector2
maybe I was not able to make the problem clear.
see images >
the issue is not visibility of the callout, the problem is the visibility of the structural column within the view.
ccollins
This is a known issue.
Try recreating the view as a Floor Plan Callout, and the structural column should appear.
Also, open the column family and make sure that "show pre-cut in plan views" is checked.
See attached.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Rail Community
