Is there a way to fade linked CAD?
2 REPLIES 2
4076 Views, 2 Replies
Is there a way besides recoloring all the layers in the linked CAD file for tracing?  Otherwise the CAD lines and the project lines have the same weight on the screen.
2 REPLIES 2
CoreyDaun
Select the Link in the View, right-click, and go to "Override Graphics in View" » "By Element...". In the following dialog under Projection Lines, you can force the lineweight to a specific value.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Thanks.  Changing surface transparency to 50% did the job.
