Hello, I was planning on doing a geodesic dome-home design in one of my architecture classes and I was wondering if anyone had any ideas on how to go about it. I have the dimensions of the house and the sizes of each triangular "panel" of the house; however, I'm not sure of how to construct it within revit. Would it even be worth the effort? Or is there another way, possibly through Autocad, if order to construct a geodesic dome easier?
It is possible in Revit, using a Conceptual Mass, thena Divided Surface, and a Pattern Based Curtain Panel applied
to the Divided Surface.
Do a search on these topics.
cheers
Cliff got to the question be fore I did, but the conceptual massing tools will probably be able to get waht you are after. Here is an example I created in about 5 minutes. It is not exactly a geodesic dome in the fact all the panels are different sizes. with a bit more math applied and some more time taken I think it could get there.
Also take a look here:
Zak shows how to use reporting parameters to check if the panels are "flat" and to report lengths of each "leg"
of the panels. His demo is not on a pure dome shape, but a similar approach could be applied to the geodesic dome.
cheers
I've written a script to build a 2v and 3v geodesic dome using the Fusion 360 api.
I've been learning python and the API as I go along so I'm sure they could be made more efficient but they both do the job.
Here are the spheres I've made
Hey
I did this for my college project back in 2013.
You should be able to follow this playlist and get the result you are looking for. It will give the option of a fully parametric geodesic dome and ability to swap out glazed, framed panels etc.
https://www.youtube.com/watch?v=9yuLKtj-ELc
This is part one, i think there about 6-7 videos
Sure, my plugin is available in this repo: https://gitlab.com/dahousecat/geodesic-py
I have installed your plugin but I run into an error whenever I try to run it. Do you know what could be causing this?
Sure, I'd just left a few calls to log to a debug file in there.
I've now removed them and deleted some unnecesary files from the repo.
Go ahead and download a fresh copy and it should work.
Thank you for your response. I downloaded a fresh install of the add-on and reinstalled it but I am getting the same error message. I am not familiar with Python so I am at a bit of a loss.
Arr yep, my mistake. I removed the calls to log, but not to clear log.
I've updated the repo again - hopefully this time it will work for you.
If not just let me know the error again and we'll work it out.
Hope this works for you!
Cheers,
Felix
Thank you for the fix. The add-on works well now for an icosahedron and dodecahedron, but I get the following error for an octahedron, cube, and tetrahedron. Do you know what might be causing this?
