Is Revit 2015 compatible with Windows 8.1?
Solved by prechav1968. Go to Solution.
Solved by scott_d_davis. Go to Solution.
Operating System | |
Microsoft® Windows® 7 SP1 64-bit: Windows 7 Enterprise, Ultimate, Professional, or Home Premium Microsoft® Windows® 8 64-bit: Windows 8 Enterprise, Pro, or Windows 8 Microsoft® Windows® 8.1 64-bit: Windows 8.1 Enterprise, Pro, or Windows 8.1 |
I have downloaded Revit 2015 and installed it on to Windows 8.1 pro, after I partitioned my hard drive on a mac book pro. When i open Revit it begins freezing and there is flickering on the book tool bar. Can you suggest anything?
I'm having the same problem. I have an Dell 9530 and I can't use Revit 2015 and Vasari because of theses unsolved problems.
hi,
i had the same problem , I unstalled 2015 then installed 2013, it worked then installed 2014 it crashed when i increased it to 200%( default) Ireduced it to 150% clicked apply button and it rebooted , and it worked, then applied the same to 2015 and now it is working . I was not clicking the APPLY button but was restarting manually, and the problem continued. Start off at 100%, 125% and see the performance. The only problem Is the buttons on the bootom toolbar ribbon are small
HOW TO DO IT
-Right click on your desk top and click on DISPLAY (left bottom corner)
- increase or reduce the % 200%(default) and click APPLY then test REVIT
If the % is not displayed make sure the LET ME CHOOSE ONE SCALING LEVEL FOR ALL MY DISPLAYS is ticked
please let me know if it works for the benefit of othets
Hello, I'm having this problem, when I try to install Revit 2015 Try Version on Windows 8.1, all the process run but then at the end it says that everything failed and nothing gets installed. I'm allready desperated! Help please! And regards.
No, I did not.
When you update from Windows 8 to Widows 8.1, it doesn´t work anymore.
hi,
i had the same problem its the graphics card problem, I unstalled 2015 then installed 2013, it worked then installed 2014 it crashed when i increased it to 200%( default) I reduced it to 150% clicked apply button and it rebooted , and it worked, then applied the same to 2015 and now it is working . I was not clicking the APPLY button but was restarting manually, and the problem continued. Start off at 100%, 125% and see the performance. The only problem Is the buttons on the bottom toolbar ribbon are small
HOW TO DO IT
Hi @anaarchi06 Did you try the solution provided by prechav1968 above your post?
Hi Lynn Zhang
No, I gave up. My Dell Inspiron 15R 5537-A20 (16GB RAM) is not compatible with Windows 8.1. So far, Dell and Microsoft have not found a solution for this problem.
Pedro Aroso
Thanks prechav1968
Yes this worked for me.
Thank god bars stopped flashing, I had an issue with trying to work and the program not responding when up to third image, having to end program through Task Manager.
I had all IT guys checking this for me and updating everything and I re installed Revit about 5 times.
This is the only thing that worked!!!
I went through [Control Panel / Display], as the correct option was not there when I right clicked.
