Inventor to Revit
15 REPLIES 15
Message 1 of 16
llamas91
12383 Views, 15 Replies
Inventor to Revit
I model everything in Inventor, but were gonan soon have to start offering downloadable models on our website.
One of them being a Revit file. I can export the model to adsk format but when i open the model it shows up in a large box. But if i click on the box, it appears that my model is inside. channging visual styles does nothing.
Any suggestions on how to resolve this?
15 REPLIES 15
Message 2 of 16
scott_d_davis
in reply to: llamas91
What version of Inventor?  The 2014 version can save a file as an RFA (Revit Family). I would not export as an ADSK, as this is really just a DWG.
Scott D Davis
Sr AEC Technical Specialist
Message 3 of 16
llamas91
in reply to: scott_d_davis
I'm using 2014 Inventor, and 2014 Revit.
Could you explain to me, how to export my inventor model to RFA format?
I don't see it as an option.
Message 4 of 16
DarrenP
enviroments tab>bim exchange
DarrenP
Message 5 of 16
llamas91
in reply to: DarrenP
Ok, so i see the options when i export a single part. But i need to export an assembly. The problem here is that the .rfa option doesnt appear. All i get is just adsk.
Is Inventor installed wrong?
Message 6 of 16
UHayes
The adsk file is what you will need to export an assembly as in order to get it to work as a Revit family.  The next step is to open the file and then save it as an RFA file.  The box that your assembly is inside of is the Coarse Detail representation of the assembly for Revit, the Medium and Fine Detail will show the actually assembly.
Message 7 of 16
reginaldmb
Hi Scott
It takes quite some time to simplify the model, save as revit file and update in the revit model each time one makes a change to the model in inventor. we typically do pump station pipework and support details inventor and then import that into the revit building. Is there not a way to create a dynamic link to the inventor model and the revit model? That way the revit model will update automatically when re-opening the file. If not, can we add this to the wish list?
Regards
Reginald
Message 8 of 16
oyoboy226
hi. i've tried to delete the box and delete it. only to select that box. and save as .RFA try it... goodluck
Message 9 of 16
oyoboy226
in reply to: oyoboy226
sorry about my sentence... what i mean is try to select the box and UNPIN the assy... and deselect only your Assy drawing/design...
Message 10 of 16
oyoboy226
select first the box... and find the PIN... click to disable the lock... then, delete the blue box...
Message 11 of 16
Kspudat
you have to un-pin in revit and delete the boundary box. We are having the same problems
Message 12 of 16
Viveka_CD
Hi @llamas91
Please see Inventor to Revit Family File (RFA) Workflow
Also, see HERE for more information on how to Author and publish models so you can use them with AutoCAD and Revit.
See HERE for using the Simplify tools to reduce model complexity for faster referencing throughout your design process.
See a short video below on Inventor 2014 BIM Exchange to Revit Family process
Please mark this response as "Accept as Solution" if it answers your question and to help others seeking similar solutions. Kudos gladly accepted.
Message 13 of 16
steven.kingsley
in reply to: Viveka_CD
Apologies for jumping into the middle of someone else's thread...
If we are embedding this item in concrete does this process result in a geometry Revit can recognise and cut concrete to suit around?
Message 14 of 16
sriragu
I had the same issue. i tried the built-in transfer from Inventor to Revit, although i got rfa files, they weren't what i wanted. my entire model just came in as one block and it was basically just a bulk imported geometry. then i came across this tool inventor to revit exporter developed by bim-dex, through google search and i am now using a trial version of the plugin. it does what i exactly need and it is in many ways better than the inventor built-in transfer. if you are looking for better results from taking inventor assemblies to revit, i would definitely suggest this tool.
Regards
Sri
Message 15 of 16
Viveka_CD
in reply to: sriragu
Message 16 of 16
JOJO.S
I am using the same workflow of converting ipt/iam to rfa. It appears fine when you view the objects from the outside, but you cannot get any section view from it. Anybody notice the same?
The solution is to fully explode the object. But not all objects can be fully explode.
What should I do to get a section view for the objects that cannot be fully exploded?
