Hello again,
I drew some internal walls before adding a floor slab.
After adding the floor slab the walls disappeared in plan. I can see them in 3D, in the correct place, but not in plan. The floor slab is in the right position. To fix the problem I redrew them all, but why did they disappear and how do I prevent it from happening again?
Thanks in advance.
N.
Thank you for your posting. Do you have any sample files or screenshots of this issue?
