Revit Architecture
Distinguished Contributor
Message 1 of 5 (530 Views)
Accepted Solution
Instance Length Family Parameter: Reporting Issue
530 Views, 4 Replies
06-25-2012 02:44 PM
I'm trying to create a simple 8x2 extrusion that will represent an aluminum band on a building elevation. The length varies by instance but needs to be reportable in a schedule (preferably using the "Length" shared parameter name.
I've never used reporting parameters before but have made an attempt at it in the attached file. The parameter of Length displays the stretched length in the properties box but won't appear in a schedule. The Instance Length parameter will appear in a schedule but doesn't always show the correct value.
I'll note that this family was adapted from one already created by someone else and the Length label cannot be deleted. It's as if the file was at one time a template.  However, I've tried it from scratch,t oo and can't get it to work, sometimes not even being able to get the family to allow stretching the length.
There's obviously a basic concept for this that I'm not grasping.  Any help would be appreciated.
*Expert Elite*
Alfredo_Medina
Message 2 of 5 (516 Views)
Re: Instance Length Family Parameter: Reporting Issue
06-26-2012 04:09 AM in reply to: paul.ashley
If you want to schedule the length value of a family in a project, you need to associate that length with a shared parameter (instance, length), in the family. Then, in the project, from the schedule, add the shared parameter to the schedule.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Message 3 of 5 (510 Views)
06-26-2012 04:54 AM in reply to: Alfredo_Medina
Late last night I found an article that suggested to me that what you offered might be the solution.  I'll give it a try today.  Thanks.
New Member
Message 4 of 5 (417 Views)
11-30-2012 10:12 AM in reply to: paul.ashley
Sorry to bump a post from June, but I have a question about the procedure to associate "length" with a shared paramter.
Any links to how to do this, or could someone point me in the proper direction?
*Expert Elite*
CADastrophe
Message 5 of 5 (412 Views)
11-30-2012 10:38 AM in reply to: luxdesigns
To associate the Shared Parameter to the Reporting Parameter, you only need to enter the exact name of the Reporting Parameter as the formula for the Shared Parameter. This will create a direct dependency to that value.
And bump-away! If the question is directly related to the thread, it's better to add to it than to start a new thread.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
