Revit Architecture
New Member
restender2000
Message 1 of 6 (573 Views)
Inches to the fourth power error
573 Views, 5 Replies
11-27-2013 06:44 AM
Inches to the fourth power error:
PLTW CEA student saved a habitat project.  He is unable to open the file and gets an inched to the fourth prompt when trying to open the file.
CADastrophe
Message 2 of 6 (565 Views)
Re: Inches to the fourth power error
11-27-2013 07:17 AM in reply to: restender2000
Hello, welcome to the Discussion Groups!
Typically, this enigmatic error indicates that there is insufficient disk space.
New Member
restender2000
Message 3 of 6 (563 Views)
11-27-2013 07:32 AM in reply to: CADastrophe
With the insignificant disc space-if disc space is cleared up, will the file open.
Or, will the student need to clear up disc space and then restart?
Rachel Stender, P.E. (inactive) MBA
Engineering Department Head
Walt Whitman High School
7100 Whittier Blvd.
Bethesda MD, 20817
301-320-6607
CADastrophe
Message 4 of 6 (560 Views)
11-27-2013 07:41 AM in reply to: restender2000
I've not encountered this error myself so I am uncertain, but I imagine he would be able to open it without restarting. If the problem persists, try restarting it then. If you have any more trouble with this error, search this board for the term "Fourth Power" and there should be some additional information that pops up from previous threads.
New Member
lukethedigitalengineer
Message 5 of 6 (94 Views)
05-08-2014 03:09 AM in reply to: CADastrophe
I have encountered this same issue. However I have tried copying the file to my desktop and with 110GB of free space I am still unable to open this 28MB file. Any ideas?
CADastrophe
Message 6 of 6 (88 Views)
05-08-2014 05:40 AM in reply to: lukethedigitalengineer
Have you had this problem with other files of comparable size? If not, you may have a corrupt file, as suggested as a possibility in this thread so I would suggest opening a Support Case with Autodesk Support, if you are on subscription.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
