Importing dwg and and make a detail
2 REPLIES 2
236 Views, 2 Replies
I'm trying to make a layoout on Revit. I have done sections and plans made on Revit and all is ok. But when I try to create a rectangular detail, such as in Plan, which contains a CAD file, I noticed that since the center of Revit is not aligned with the center of the dwg, the detail is moved and takes up a very large rectangle . When I try to drag the window "detail of Plan" within the table layout, the rectangle occupies the entire sheet.
I know the obvious solution would be to align the two centers, but since I have more parts I would know how to fix it. Maybe I'm wrong with some setting?
2 REPLIES 2
GHASEM_ARIYANI
Hi
AutoCAD files of coordinates 0 and 0 put and in the Revit Import CAD dialog, you set Import Units with units Project file and Choice Positioning Auto-Orgin to Orgin.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
in reply to: GHASEM_ARIYANI
It doesn't work.  Maybe these pics can help me..
