Revit Architecture
*John Gray
Message 1 of 3 (294 Views)
Importing Microstation V8 files
294 Views, 2 Replies
01-24-2006 10:20 AM
Is it possible to import Microstation V8 files into Revit Building 8.1? At
first glance it is not possible. The option of saving back or working in
DWG mode in microstaion is not an option unfortuently.
John Gray
Distinguished Contributor
Message 2 of 3 (294 Views)
Re: Importing Microstation V8 files
01-24-2006 09:58 PM in reply to: *John Gray
Since Bentley put so much marketing and engineering effort into making Microstation able to read dwg files "natively" I'm afraid support for dgn past Version J "died". Since Autodesk has owned Revit I'm not aware of any additional support for dgn and I've never heard a peep, rumors or otherwise, about reviving support for newer versions of dgn.
Sorry, the only route available to you IS to SaveAS to version 7/J or SaveAS to dwg/dxf...or possibly IFC. I don't know what Bentley is up to with IFC though.
*E L S
Message 3 of 3 (294 Views)
01-25-2006 05:14 AM in reply to: *John Gray
How much work do you want to do?
If you are willing to take a few steps, install some software, keep
reading. Otherwise, disregard this message.
First, install Bentley's DGN viewer. Available as a free download from
their website (www.bentley.com)
Open the file and print to PDF.
You can use Ghostscript/Ghostview/pstoedit to convert PDF files
Download Ghostscript, GhostView and pstoedit all available here.
(http://www.cs.wisc.edu/~ghost/gsview/) Follow the directions for
installation for each program.
Then in GhostView open the PDF and convert it to DXF
(http://www.stillhq.com/ctpfaq/2002/03/c727.html#AEN914)
HTH
> Thanks,
> John Gray
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
