Or at the very least create an 'interfeance model' of the slicer, that
just approximates it's required outside clearances, and bring the
DWG's you've got into the Family and set the visibility controls so
that they are what shows in plan & elevation, yet you still have this
3D form you can use to check clearances and such... it might be faster...
Jeffrey McGrew
melarch wrote:
> Nathan,
> Why are you trying to bring a 2D plan and elevation for this meat slicing equipment? If you are trying to model this meat slicer you may want to create a family using the family editor. 2D geometry is not going to represent its image properly in Revit model views and it is apparent that what you need to show is a 3D model of this meat slicer.
> You of course could try to build it as an in-place family, but the same effort you would spend trying to create this model would be better served using the family editor to create this equipment.
> Read the tutorials on using the family editor to create family content. Also visit Autodesk family library, AUGI and Revit City to look for a family that looks like a meat slicer, maybe if one can be found you can use and modify that family to the model you need to develop.
> Mel Persin, Architect & Consultant/Trainer
