I have created a model within revit architecture 2013 which I want to export as a gbxmL and open in the open studio 1.1.0 interface within sketchup. When I export the gbxmL model into sketchup it does not have a floor, and an error saying surface has two adjacent spaces which are the same space (warning repeated for each room), room will not be translated, and also surface has no adjacent spaces, will not be translated appears.
All spaces are bound to the floor and roof, and zones are correctly assigned, and the model has a location. There are no errors when the export to gbxml is to take place for analytical surfaces or for the rooms. Does anybody know what might be wrong in the way I have assigned rooms/spaces? And also why no floor is appearing?
Cheers,
Caitlin
Did you ever manage to find a solution to that problem? I am getting exactly the same mysterious error and apparently there's something not quite right with the export/import of the gbxml, and not so much with the model itself?
Thanks in advance!
Ira
