Revit Architecture
dlam
Message 1 of 2 (2,060 Views)
Import Tekla file into Revit
2060 Views, 1 Replies
03-08-2012 10:03 AM
Which is a better solution in terms of not losing any of the geometry of the model from Tekla to Revit?
Directly export Tekla file to Revit file using the "Export to Revit" application inside Tekla software?
Or directly export Tekla file to IFC file format?
Product Support
Message 2 of 2 (2,002 Views)
Re: Import Tekla file into Revit
04-05-2012 12:16 PM in reply to: dlam
I found the following FAQ for Tekla Revit interoperability:
http://www.tekla.com/international/solutions/building-construction/Pages/tekla-revit-questions-and-a...
Question 4 has information relevant to your question:
4. What is the file format used in this linking?
The users will have Export to Tekla and Export to Revit buttons available in respective software to create exchange files. The data transfer is based on the IFC format but will be extended beyond the IFCs. The IFC format is the common ground for this but not a limitation.
From the answer above, it sounds like the Tekla export option will output more information than IFC would.
Lance Coffey
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
