Import SAT or STEP then export to IFC
2 REPLIES 2
TeunHam
2697 Views, 2 Replies
I need to create an IFC file, but the contents of my Revit file is an imported SAT or STEP file.
The export to IFC results in an empty IFC, as the SAT/STEP is not being exported to IFC.
I need this geometry to be exported to IFC!
How?
2 REPLIES 2
GHASEM_ARIYANI
in reply to: TeunHam
Hi
Revit logo high on the left and click to open the list of export options, and then select the IFC.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
Environment in of the Conceptual Mass can also import CAD And then open the Import CAD Formats, List Files of type, select the desired format to be imported.
Click on the Load into project to make the project environment.
This way your file is known as Conceptual Mass and tools like Wall bay face or roof bay face or floor bay face on those acts
