Revit Architecture
New Member
Message 1 of 3 (748 Views)
Import 3D AutoCAD model into Revit
748 Views, 2 Replies
09-19-2013 03:40 AM
i have a 3d model created in autocad , i am trying to import it to revit , as you know it comes in as a block i need it to come in or be converted to a normal version so things can be selected indivdualy.
can anyone think of a solution ???
Edited by
Discussion_Admin
*Expert Elite*
CADastrophe
Message 2 of 3 (727 Views)
Re: Import 3D AutoCAD model into Revit
09-19-2013 06:12 AM in reply to: deanmcminn101
Hi Dean! Welcome to the Discussion Groups!
I do not believe that there is any way to directly convert AutoCAD object into Revit elements - basically, you can link it into a Revit Project and use it as a guide to create the Revit Model.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Mentor
gh_ar
Message 3 of 3 (688 Views)
09-20-2013 02:02 AM in reply to: deanmcminn101
Hi
You can file AutoCAD 3D As Mass Model Import In the Revit.
The following method:
1-Open the Metric Mass Template.
2-Insert CAD Formate in the Metric Mass Space.
3-Open the Project Template.
4-Return to the environment Metric Mass(CTRL+TAB).
5-Click on the LOAD INTO PROJECT Bottom.(FileAutoCAD As File Mass Import The project is.)
6-Now  You can the tools Such as Pick Wall By Face or Pick Roof Roof By  face It the file Revit Conversion To.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
