Revit Architecture
Active Member
OXARCHITECTS
Message 1 of 5 (3,016 Views)
Accepted Solution
IMPORTED DWG - CAN'T FIND- LOCATE IN PROJECT
3016 Views, 4 Replies
12-07-2011 12:21 PM
Please see SCREENSHOT VG.  I imported an AutoCAD file call A-LAN-CEN-XP-01.dwg. Now I would like to delete the drawing from the project.  I can't find it anywhere in the project. It's lost.   Do I have to go through every project view and every display setting per view to seek out the location of this .dwg in order to select and delete it?  Or is there another way?
*Expert Elite*
Message 2 of 5 (3,007 Views)
Re: IMPORTED DWG - CAN'T FIND- LOCATE IN PROJECT
12-07-2011 01:33 PM in reply to: OXARCHITECTS
Did you insert the CAD or did you link it?  If you linked it, go to Manage tab --> Manage Links --> CAD Formats and Remove the link.
If you inserted the CAD file directly (shame on you), go to Manage tab --> Purge Unused, click Select None, then scroll down to where you see the name of the file.  If it's not being used in the project, you'll be able to see it here.  Just check the box next to it and click OK.
If you don't see it there, then there's still an instance of it somewhere in your project, and you'll have to hunt it down.
Ross Kirby
BIM Manager
Arcturis
Active Member
OXARCHITECTS
Message 3 of 5 (3,000 Views)
12-07-2011 02:53 PM in reply to: rosskirby
"shame on you". I know, I know.  I feel the shame.  Now I know better.  Thank you for the reply.  Your suggestion to purge the file worked.  It was burried in a group.
*Expert Elite*
Message 4 of 5 (2,995 Views)
12-07-2011 05:41 PM in reply to: OXARCHITECTS
Glad that worked out for you. The "shame on you" was only half-serious. I've imported CAD in a pinch, when I didn't have time to do it the proper way: link and re-create.
Ross Kirby
BIM Manager
Arcturis
New Member
Message 5 of 5 (2,631 Views)
08-15-2012 08:14 PM in reply to: OXARCHITECTS
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
