You could put all the imported IFC objects on a Phase, and then use the
Phase overrides to control the materials. For instance, if you put all the
IFC objects on the out-of-the-box Existing Phase, they will all render grey,
as this is the default override material for existing objects.
"Anthony Mason"
wrote in message
news:6391696@discussion.autodesk.com...
There are 450 of those in the list. Any way to change them all at once?
On 5/14/2010 9:57 AM, vector2 wrote:
> when you import the IFC or any import-
> look in the materials list and see
> "render material" with a bunch of
> numbers after it.. change them
> to whatever material you want
> for the import..
Anthony Mason
http://dailyoccurrence.wordpress.com/
