I am doing some tests to export my model out to IFC. The slabs and walls do not line up. Can anyone recommend a fix, or is anyone having the same issue in Revit 2012?
Jordan
I confirmed with AutoDesk that the Revit 2012 IFC Export is indeed broken and will be updated in a future (hopefully soon) release.
Jordan
That's quite annoying. At least we can use roof element instead of floor, those seem to stay in their places.
Do you have a help desk ticket number? I am severely hindered by this flaw. My beams and columns come out right, but my floors are way off to the side when exporting a 3d view.
I am shocked that Autodesk has messed this up...
Thanks buddy.... in the meantime I have not been able to find a work around. I can't back-save to Revit 2011, I can't install the Tekla plugin because its only for Revit 2011, and exporting to dwg then ifc from AutoCAD changes the Selection Tree in Navis.
Let me know if you find one.
THanks again,
DF
So replacing floors with roof objects is not an option for you?
However, I noticed that same bug is with building pad. And I don't think there is a workaround for this one.
I am not trying to be smug, but I am not going to put bad information into my model in order to work around a software problem.
My clients want open source deliverables (so we all trade rvt during the design, thats fine), so I cannot handover rvt
4 months on - anyone seen a fix?
The Fix is actually available since june 2011. However, on autodesk's site it is not under Revit's Updates section but under Product Download. Nothing about IFC is mentioned in Update Enhancement List also, but the update fixed my problem with slabs and pads during IFC export.
yes that update fixed SOME of the export problems but not all. I have circle holes in my slabs and these holes become mystery slabs outside the building as I export to IFC.
Dear Eeva,
thank you for calling our attention to this issue. In the meantime, as you have confirmed as well, it seems to be a solution for this issue. It is fixed in the update2 for RST 2012.
You can download it from this link: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16840966
Kind regards,
