IF statments
5 REPLIES 5
sham.summan
273 Views, 5 Replies
IF statments
I am trying to make a nested window family which contains both an open and fixed panes which can be controlled with visibility .
I have the following visibility  Yes / No parameter
Hung – Top
Hung – Bottom
Hung – Left
Hung – Right
Frame – Opening
Frame - Fixed
I am trying to control the visibility of the Frame - Opening and Frame – Fixed from the values of the hung properties.
If any of the hung values are set on I would like Frame – Opening to be on.
If non of the hung values are selected I want Frame – Opening to be switch off and Frame - Fixed to be on.
Sure this is very simple of someone out there.
Any helps is appreciated.
S
5 REPLIES 5
L.Maas
in reply to: sham.summan
The easiest way is to use "and" "or" "not" statements in a formula
in the formula for "Frame - Opening"
=or(Hung – Top, Hung – Bottom, Hung – Left, Hung – Right)
This means if any of the value are true then "yes"
in the formula for "Frame - Fixed"
=Not(Frame - Opening)
Louis
Please mention Revit version, especially when uploading Revit files.
sham.summan
in reply to: L.Maas
perfect,
Don't use that hyphen or dash symbol in the name of a parameter. Revit might understand that as a "minus" symbol when you use any of those parameters in a formula.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
How can this ne inverted,  If something is off,  then put something on.?
David_W_Koch
Use the NOT operator, as shown above.
If you have one parameter that can be either Yes or No (such as a Yes/No paramater that offers a check box in the properties), then setting up a second Yes/No parameter and assigning a formula of
not(ParameterName)
will give you the inverse, or negation, of that first parameter (where ParameterName is the name you gave the first parameter).
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
