I cannot select curtain panels - 2014
14 REPLIES 14
Message 1 of 15
bthatcher
5924 Views, 14 Replies
I cannot seem to select the panel in thte curtain wall. As if I were going to place a door. I have all of the new selection options on in 2014. What changed and how do I select thte panel? Thanks.
14 REPLIES 14
Message 2 of 15
in reply to: bthatcher
Not aware of any changes. I just toggle through until the panel comes up just as it has in previous versions.
Message 3 of 15
Hi -
I'm having the same problem and cannot find a solution. Have done it before many times but does not seem to now work?? I can select the grid line or the entire curtain wall, but nothing else. Did you end up finding a solution?
Message 4 of 15
arunag
put on the 'select element by face' in status bar below & tab near the panel to see it highlighted & then click.
If this is tedious, make crossing selection of the panel & filter  out curtain panel from it.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Message 5 of 15
M-Town_Drafter
in reply to: arunag
You're allowed to prevent selecting pinned element, which curtain panels typically are.  Check the bottom right, the little pin symbol.  Make sure there's no red 'X' with it, as that may be the problem.
Message 6 of 15
in reply to: M-Town_Drafter
Press Tab + Mouse to switch from the various elements within the drawing
Message 7 of 15
hjlcanton
not helping
Message 8 of 15
hjlcanton
not the reason in this case
Message 9 of 15
hjlcanton
in reply to: arunag
neither of them work in 2019
Message 10 of 15
in reply to: hjlcanton
Make sure no red X iver th3 small icons on the bottom right status bar then you can TAB + hover the cursor over a curtain panel to select it.
Message 11 of 15
hjlcanton
in reply to: ToanDN
yes, it works, thank you so much.
and also thanks to the above answerers.
Message 12 of 15
Michelle_Chedraui
Hi - This is happening to me. Did you find a solution?
Message 13 of 15
Michelle_Chedraui
in reply to: ToanDN
this worked for me 🙂
Message 14 of 15
This solved it for me on Revit 2022. Thank you so much.
Message 15 of 15
you are a lifesaver!!!
