I cannot seem to select the panel in thte curtain wall. As if I were going to place a door. I have all of the new selection options on in 2014. What changed and how do I select thte panel? Thanks.
Not aware of any changes. I just toggle through until the panel comes up just as it has in previous versions.
Hi -
I'm having the same problem and cannot find a solution. Have done it before many times but does not seem to now work?? I can select the grid line or the entire curtain wall, but nothing else. Did you end up finding a solution?
put on the 'select element by face' in status bar below & tab near the panel to see it highlighted & then click.
If this is tedious, make crossing selection of the panel & filter out curtain panel from it.
You're allowed to prevent selecting pinned element, which curtain panels typically are. Check the bottom right, the little pin symbol. Make sure there's no red 'X' with it, as that may be the problem.
Press Tab + Mouse to switch from the various elements within the drawing
