Revit Architecture
*Leo Gonzales
Message 1 of 6 (567 Views)
How to purge an imported dwg object with all of its layers deleted
567 Views, 5 Replies
01-25-2006 01:27 PM
I have a revit file with an imported dwg object. I accidentally deleted all
of its layers. How can I purge the object out of the revit file?
Leo
Distinguished Contributor
melarch
Message 2 of 6 (567 Views)
Re: How to purge an imported dwg object with all of its layers deleted
01-30-2006 05:54 AM in reply to: *Leo Gonzales
It would appear that deleting all of the layers for an Imported object purges the drawing out of the Revit project file. I checked the Visibility Graphics tab for Imported Categories and when I deleted all of the Layers including "0" the DWG was no longer listed.
What is more critical is when you delete all of the layers in an imported DWG, except those have no objects on them at all. Then try to purge or delete it from the Revit project file. Since no entities remain on a layer or are visible with which to select the imported DWG, you cannot delete it from the Revit project file.
Mel Persin, AIA
melarch
Message 3 of 6 (567 Views)
01-30-2006 06:35 AM in reply to: *Leo Gonzales
The answer was found in a thread on AUGI's Revit forum "Lost Import"
To get rid of any remaining layers from an imported DWG without entities. Open Visibility Graphics, select the layers in question and pick the Object Styles button at the bottom of the dialog box. In the Object Styles dialog box in the Imported Objects tab select the layers and Delete them.
But this does not remove the imported DWG file from either the Object Styles or Visibility Graphics. Which suggests that the imported DWG is still in your Revit project file.
I have not found the answer to purging the imported DWG file in the above scenarios
Mel Persin, AIA
Dirk Redhead
Message 4 of 6 (567 Views)
02-23-2006 12:44 PM in reply to: *Leo Gonzales
Autodesk? Please help on this one.
Dirk Redhead
Message 5 of 6 (567 Views)
03-01-2006 12:37 PM in reply to: *Leo Gonzales
Please?
Member
Clntnco
Message 6 of 6 (140 Views)
01-21-2014 02:29 PM in reply to: *Leo Gonzales
Goto Manage > Object Styles > Imported Objects >
and then you should see each drawing that was imported
delete the layers from each individual drawing and then you should be able to purge the drawings out.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
