I have an section view in which the dotted hatching (texture) of the Gypboard walls seen in elevation in the rear is too strong or too heavy. I want to completely eliminate this "strong" hatching on the elevation of these Gypboard walls, or at least mofify or soften the hatching with a larger scale hath or maybe grayed.
Where or how do I manipulate the hatching for the elevation of these Gypboard walls? May want to do it on this view only, as a beginning learning exercise.
Thnks in advance.
Solved by constantin.stroescu. Go to Solution.
Go to wall editing. In "Material Browser" surface pattern should be "none". Then it would be shown clear in elevation.
Thanks & regards,
Subhradeep Sen
Kolkata
India
In sectional elevation you do one thing. go to Annonate>Region>Filled Region. Filled with solid hatch and color should be white. Then you will not able to see those hatches in sectional elevation.
of course, you can change material appearance, but if you want to do the change only in one View ( for instance, as you said, in a section view as background image ) then use an override by category...you can use halfrtoning and/or Surface Pattern override
Your Name
Constantin's override worked (I chose "Override by Element and it seems to be working for that view only).
Thanks to all who responded.
