How to make rounded edge wall and roof
1 REPLY 1
1111 Views, 1 Reply
I am trying to get my drawings into revit but I am stuck on getting the basic form of the building in Revit.
Since I am using slanted walls I need to work with a Mass but I can't get the mass look like my idea. The picture I attached is a simpel screen caputre of Rhino withthe outline of the building.
I hope you guys can help!
Tags (1)
1 REPLY 1
scott_d_davis
draw the same profile you used in Rhino, on the surface vertical workplane in the Mass Editor in Revit, and then use the Create Form buttom to turn the profile into an extrusion.
Scott D Davis
Sr AEC Technical Specialist
