How to determine the distance between the two “flights” of the stair?
2 REPLIES 2
JamaL9722060
498 Views, 2 Replies
I couldn’t find the option through which the distance between the two flights is determined.
Also, I have no idea how to create another landing at the end of the stair!
Thank you for the help,
Best
Jamal
Jamal Numan
2 REPLIES 2
in reply to: JamaL9722060
You need to edit the stair sketch to change the dimension between the flights. You can also edit the stair sketch to increase the length of the last tread to make it a landing by moving the last line.
JamaL9722060
Thank you for the answer.
In the screenshot below, I attempt to change the length of the distance betwwen the two flights but sounds that there is no option to do that!
What might be the solution?
Best
Jamal
Jamal Numan
