Revit Architecture
JamaL9722060
Message 1 of 5 (1,086 Views)
How to delete a particular “dimension line”?
1086 Views, 4 Replies
10-02-2012 02:06 PM
I wanted to delete one of the “dimension lines” but sounds to delete all the connected dimension
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
parveen.revit
Message 2 of 5 (1,077 Views)
Re: How to delete a particular “dimension line”?
10-02-2012 10:23 PM in reply to: JamaL9722060
you can select that dimension and click on the reference point/element to remove that dimension.
that distance (dimension value) will be added to next dimension.
direct delete is not possible.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
JamaL9722060
Message 3 of 5 (1,058 Views)
10-03-2012 02:07 PM in reply to: parveen.revit
Thank you for the answer.
For example, in the screenshot below, I wanted to delete the dimension 1.4, but couldn’t know where to click in order to delete it.
Firefox 20.0,
Kaspersky 2013.
CADastrophe
Message 4 of 5 (1,054 Views)
10-03-2012 02:14 PM in reply to: JamaL9722060
In Revit 2013, you can hover the mouse over a segment of continuous dimensions, press tab to highlight that particular segment, and delete it.
This is not possible in prior releases of Revit.
JamaL9722060
Message 5 of 5 (1,030 Views)
10-05-2012 01:41 AM in reply to: CADastrophe
many thanks. this is much easier.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
