How to delete a particular “dimension line”?
4 REPLIES 4
JamaL9722060
5148 Views, 4 Replies
I wanted to delete one of the “dimension lines” but sounds to delete all the connected dimension
Best
Jamal
Jamal Numan
4 REPLIES 4
you can select that dimension and click on the reference point/element to remove that dimension.
that distance (dimension value) will be added to next dimension.
direct delete is not possible.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Thank you for the answer.
For example, in the screenshot below, I wanted to delete the dimension 1.4, but couldn’t know where to click in order to delete it.
Jamal Numan
CoreyDaun
in reply to: JamaL9722060
In Revit 2013, you can hover the mouse over a segment of continuous dimensions, press tab to highlight that particular segment, and delete it.
This is not possible in prior releases of Revit.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
JamaL9722060
in reply to: CoreyDaun
many thanks. this is much easier.
best
Jamal
Jamal Numan
