I'm trying to create a sloped glazing roof but I'm having problems with the end mullion. I wanted Revit to cut the last mullion so that the boundary that I defined is completely covered. As it seems, Revit either adds a complete last mullion, surpassing the boundary, or removes the last mullion, creating a hole on the roof. I tried using a vertical shaft to cut the last mullion that surpasses the prescribed boundary but had no success..
How would you accomplish this?
Solved by ruipfbarreiros. Go to Solution.
Hi, have you tried a void to cut the mullion instead of a shaft? Shafts only cuts floors and roofs, i think. But i've created a sloped roof here, with a chamfer in one of the corners so the end mullion gets shorter, and worked fine. Could you post a image of what you're trying to do?
Gustavo
I can try that...I thought there would be a faster and cleaner way though...
I just realized that the sloped glazing roofs adds an empty system panel at each grid...i can use that to cut the mullion....
thanks
