Revit Architecture
Distinguished Contributor
ruipfbarreiros
Message 1 of 3 (167 Views)
How to cut a mullion?
167 Views, 2 Replies
01-27-2014 06:55 AM
I'm trying to create a sloped glazing roof but I'm having problems with the end mullion. I wanted Revit to cut the last mullion so that the boundary that I defined is completely covered. As it seems, Revit either adds a complete last mullion, surpassing the boundary, or removes the last mullion, creating a hole on the roof. I tried using a vertical shaft to cut the last mullion that surpasses the prescribed boundary but had no success..
How would you accomplish this?
Using Building Design Suite Ultimate 2014
Valued Contributor
gustavomello
Message 2 of 3 (158 Views)
Re: How to cut a mullion?
01-27-2014 07:19 AM in reply to: ruipfbarreiros
Hi, have you tried a void to cut the mullion instead of a shaft? Shafts only cuts floors and roofs, i think. But i've created a sloped roof here, with a chamfer in one of the corners so the end mullion gets shorter, and worked fine. Could you post a image of what you're trying to do?
Gustavo
ruipfbarreiros
Message 3 of 3 (152 Views)
01-27-2014 07:43 AM in reply to: gustavomello
I can try that...I thought there would be a faster and cleaner way though...
I just realized that the sloped glazing roofs adds an empty system panel at each grid...i can use that to cut the mullion....
thanks
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
